PP Titler, Exporting credit roll to reimport in another project
John Watts
on Oct 23, 2018 at 12:43:53 am
Very new to the titler on PP.
I have a credit roll and a few still pages. Essentially the same from show to show.
I am able to cut and paste these from project to project, but, feel that is a bad practice if a project was deleted prematurely I would be out of luck.
Would like to export these to a folder that I can then import into the next project. Especially important is the credit roll, in which I need to vary the length and speed from show to show.
Is there a way? Or am I dreaming?
Googling is failing me so far.
Good Luck with your 2 billion dollar lottery ticket!
John Watts
Premiere Pro Version 12.1.2 Build 69
2017 iMac (Retina 5K 27 inch) 1TB SSD
4GHZ Intel Core i7
32GB 1867 MHz DDR3
Graphics AMD Radeon R9 M395X 4096 MB
macOS High Sierra Version 10.13.6
John Heiser
Re: PP Titler, Exporting credit roll to reimport in another project
on Oct 23, 2018 at 9:07:09 pm
Couple of ways to do this, I think:
- Click on your credit roll in the timeline (the clip created by Essential Graphics), then in the menu bar, click Graphics > Export as Motion Graphics Template. Give it a _short_ name and save to Essential Graphics (it will then appear in the Browse section of Essential Graphics) or to a central location you won't be deleting (and you'll have to import it from that location). Now you can use that as a starting point each time and adjust as needed.
- Save to a central location a copy of your project with the graphics, then delete everything in the project except the graphics. Now you can open that project alongside each episode's project and copy-paste-adjust as needed.
John Heiser
Senior Editor
o2 ideas
Birmingham
John Watts
on Oct 23, 2018 at 9:52:51 pm
The second way looks like the answer.
Export as motion graphic is greyed out.
John Watts
4GHZ Intel Core i7
32GB 1867 MHz DDR3
