Conforming Frame Rates in PP?
Dave LaRonde
on Oct 19, 2018 at 5:36:30 pm
I'm in the dark on conforming frame rates in PP.
I'm well aware of the speed changes that come from doing so, and the audio problems it can present.
I'd just like to know if PP can conform 29.97 video to.... oh, say, 23.976 without exporting and if possible, how to go about doing it.
PS: I'm running PP CC 2017, with no intention of installing newer versions.
Dave LaRonde
Promotion Producer
Tero Ahlfors
Re: Conforming Frame Rates in PP?
on Oct 19, 2018 at 6:31:41 pm
[Dave LaRonde] "without exporting"
Nope. You can change the frame rate of the clip in the program and export it out with the new frame rate and duration. You'd still need to do some serious audio work when going from 29.97 to 23.976. Premiere won't automatically do pitch correction.
Shane Ross
on Oct 19, 2018 at 7:20:21 pm
Conform...so make slow motion? Or have it still play in real time, but 23.98?
Shane
Little Frog Post
Dave LaRonde
on Oct 19, 2018 at 8:30:16 pm
[Shane Ross] "Conform...so make slow motion?"
Correct. Considering I'd go from 29.97 to 23.976, it's slower, but not much. No audio involved, either -- I don't need that problem.
Dave LaRonde
Promotion Producer
Shane Ross
on Oct 19, 2018 at 9:44:48 pm
You right-click on the clip...in that menu choose MODIFY and then INTERPRET FOOTAGE. Set it to the frame rate you want.
Shane
Little Frog Post
Dave LaRonde
on Oct 19, 2018 at 10:35:37 pm
Cool! I was hoping it would be easy! Thanks!
Dave LaRonde
Promotion Producer
Samuel Frazier
on Oct 20, 2018 at 1:48:19 am
Is this really any different from making the speed change to the clip once it's in a timeline (right click clip, speed/duration)? I saw a tutorial saying this would be the same thing and proposed using this formula:
frame rate of timeline*100/ frame rate of clip = rate to set in Premiere
John Pale
on Oct 20, 2018 at 1:53:49 am
Yes, it is different. Its playing all the frames at a different speed. No frame blending.
Samuel Frazier
on Oct 20, 2018 at 2:02:54 am
I was wondering if it was just that kind of frame blending vs true slomo. That's too bad. It would be handy to be able to choose which instance of a clip is to be in slomo and which is not.
Oliver Peters
on Oct 20, 2018 at 2:11:24 am
If you conform - like interpret 29.97 footage to 23.98 for a 23.98 timeline - the video will play cleanly, as if the native rate was 23.98. However, the result of doing this is identical to leaving it as 29.97 (in the browser), editing it to the timeline, and then setting the speed (right-click) to an exact 80%. Both give you 1:1 frames without blending or any interpolation.
The downside to interpret/conform is that the timecode conversion will be messed up for any roundtrips, proxy workflows, and media (project) management. I used to interpret/conform, but got burned. I now only use the slomo function.
- Oliver
Oliver Peters - oliverpeters.com
Dave LaRonde
on Oct 21, 2018 at 12:02:27 am
Thanks for the warning, but I'm aware of what happens if I conform. I'm not afraid.
Dave LaRonde
Promotion Producer
