Cut clips the same way like in Sony Vegas
Gennady Gaidukevich
on Oct 19, 2018 at 4:55:42 am
Is it possible to make some kind of hot key that would cut the clip in the place where timeline pointer is at the moment? Will try to explain you what I mean. I know there is Cut tool that you can use when press ะก but problem with it is that after I press C I need to aim with mouse pointer before I cut something and sometimes things get inaccurate. Is it possible to cut the video like in Sony Vegas where you press S and it splits the clip where your timeline pointer is. I hope you got me. Thanks in advance
Tero Ahlfors
Re: Cut clips the same way like in Sony Vegas
on Oct 19, 2018 at 6:24:00 am
Yes. Sequence - Add edit or Add edit to all tracks.
