The clips won't touch each other in Premiere Pro, what do I do?
ryan elder
on Oct 19, 2018 at 4:44:57 am
Basically I am editing on the timeline and the clips won't touch. I think I figured out the problem. Basically I was editing on a 24 fps timeline, when the videos were shot in 25 fps, which was causing frames to skip. So I copied and pasted all that I edited in a new 24 fps timeline to prevent frame skipping.
The frame skipping appears to be gone now, but now the clips won't touch in certain sections because of it. Is there a way to fix this at all?
Daniel Waldron
Re: The clips won't touch each other in Premiere Pro, what do I do?
on Oct 19, 2018 at 7:51:51 pm
You probably have to manually adjust them. Premiere doesn't know to add the extra frame that is needed.
ryan elder
on Oct 19, 2018 at 10:42:45 pm
Okay thanks, but Premiere will not let me manually adjust them, it just doesn't do anything when I try to touch the frames.
