Converting an exported h264 to Prores
Bas Steeman
on Oct 16, 2018 at 7:08:05 pm
Hello,
Is it possible to convert an h264 mp4 to Prores after it's already been exported from Premiere Pro? Or do I need to export it again with Prores settings from a Premiere Pro installation on a Mac?
I've edited a video in PP on Windows, but now the customer wants a Prores version too. I've got access to an old Macbook, but it does not have any editing software installed. Is that a problem? Or can I use Mpeg Streamclip or another (preferably free) conversion program to do it?
Thanks for any help.
Blaise Douros
Re: Converting an exported h264 to Prores
on Oct 16, 2018 at 9:54:10 pm
Exporting a ProRes version directly from the sequence will get you the best quality.
Transcoding an h.264 to ProRes is completely possible, but reduces the quality--h.264 has significant compression compared to ProRes, so you will be limited by the quality of the h.264 export if you transcode.
Bas Steeman
on Oct 16, 2018 at 10:12:40 pm
Hm, yes, I was afraid of that. Thanks for your answer.
Does it help if the h264 has been exported with a huge bitrate? Like 50Mbps, or even higher?
Shane Ross
on Oct 16, 2018 at 10:42:51 pm
Don't go to H.264 first. NO NO NO NO NO! You lose SO much information...good god no.
Export out DNxHD 175x, or Cineform....a good high quality codec. THEN take to a Mac that has Compressor (gonna need a mac with one Apple ProApp on it to convert to ProRes) and convert to ProRes.
You'll cause a lot of damage outputtting to a highly compressed format first, then converting. Bad idea.
Shane
Little Frog Post
Bas Steeman
on Oct 17, 2018 at 10:12:04 am
Thanks Shane!
I exported it as Cineform. Now to search for a Mac that can handle the conversion.
Joby Anthony Jr
on Oct 17, 2018 at 1:49:03 pm
Saw this article just yesterday. Although a year old, the info is still relevant, and might help you walk through pros, cons, and various solutions:
https://blog.frame.io/2017/08/07/prores-on-windows/
Dovetailing the article and reinforcing Shane's advice, friend with a Mac and Compressor probably your best option.
--Joby.
Bas Steeman
on Oct 17, 2018 at 2:07:54 pm
I managed to make it work with Shane's advice. I found a Mac with an older version of Premiere Pro. It couldn't read my project file, but I could import the Cineform file (with the highest settings, resulting in a 16GB file for a 5 minute 1080p 25fps video) and export that to Prores.
