Importing a FinalCut-7 Project in to the latest Adobe Premier
Rory Keenan
on Oct 2, 2018 at 7:23:27 pm
Hi
I have to go back and re-edit a feature length documentary film to new music.
The film was started several years ago and exists as a FinalCut-7 project.
The producers are buying a new MacPro and outfitting it with the Adobe Suite (Premier).
Does anyone have advice on importing a FCP-7 project in to the latest version of Premier?
Oliver Peters
Re: Importing a FinalCut-7 Project in to the latest Adobe Premier
on Oct 2, 2018 at 8:20:27 pm
You have to export an XML from FCP7 and import it into Premiere. It *may* work, but probably not flawlessly. Option 2 is to roundtrip the XML through Resolve first. But in either case, you must have an XML from the FCP7 project.
- Oliver
Oliver Peters - oliverpeters.com
David Roth Weiss
on Oct 2, 2018 at 9:25:37 pm
If you have any alternate takes or other material on any tracks that you’ve disabled, you should do a save as to create a new timeline, and then delete all that material, otherwise I can assure you that your XML will be problematic.
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
