Reversing a Multi-Cam Sequence
Andy McKenzie
on Sep 24, 2018 at 8:47:49 pm
Hello,
I am using Multi-Cam Sequences in Premiere, and most of the time they work fin but, I have a Multi-Cam that has all of the right video clips, but is using the wrong audio. Is there a way to deconstruct the multi-cam so I can still use the same clips but find a new audio clip to go with them?
Blaise Douros
Re: Reversing a Multi-Cam Sequence
on Sep 24, 2018 at 9:16:04 pm
If it's just using the audio from the wrong camera, right-click the MultiCam clip, and select "Open In Timeline." Then either move the correct camera's audio clip to the track with audio enabled, or enable the track where it is and mute the incorrect ones.
Trevor Asquerthian
on Sep 25, 2018 at 7:59:34 am
Beware audio in multicam clips in Premiere if you may ever need to flatten them. Unpredictable results are likely to ensue.
Andy McKenzie
on Sep 25, 2018 at 1:48:37 pm
Awesome thanks!
