Multiband compressor Bug
Jim Cunningham
on Sep 20, 2018 at 4:16:04 pm
Gotcha Alert!
I've noticed that if you use the multiband compressor within Premiere CC 2018, and make a duplicate copy of the sequence, all of the Multiband settings are reset to 0 in the new sequence.
Good Luck,
Jim
OS 10.13.6
iMac 5K
Premiere 12.1.2
John Pale
Re: Multiband compressor Bug
on Sep 20, 2018 at 4:33:40 pm
Not seeing that behavior, but somewhat often, when I duplicate sequences that have effects on the Master track, the effect becomes corrupted and I get nothing but loud static on output. I then end up removing and replacing the effect with a “fresh” one to fix it.
Jim Cunningham
on Sep 21, 2018 at 1:24:03 pm
There is a bug report into Adobe on this issue. I just wanted to spread the news so others don't get bitten.
Cheers,
