Sudden Render Problem (Snow)
Angel Nieves
on Aug 24, 2018 at 4:01:59 pm
This just started happening. I try to export or render, and I get glitches/snow instead of the image. When I go to the export window (see screengrab below), the image is distorted. The glitches/snow also appear on the exported movie file. I've been using this version of Premiere (2017) for over a year and never had any problems. This is happening with different projects, including projects I had exported in the past with no problems.
Angel Nieves
Re: Sudden Render Problem (Snow)
on Aug 24, 2018 at 6:07:38 pm
I figured it out. What worked for me is going to File/Project Settings/General and on the Video Rendering and Playback pull-down menu select switch to 'Mercury Playback Engine Software Only.'
