How to fix a horrible case of flickering
Omar Ayoub
on Aug 22, 2018 at 5:19:46 am
Hello,
I shot this interview some five years ago (at which point I had no time for any testing, and knew very little about the effects of a mismatch between the camera's shutter speed and the fluorescent lights I had used). Long story short, almost five hours of an incredibly important interview are plagued with constant horizontal flickering, across the whole width of the clip.
I used Digital Anarchy's Flicker Free and tested all the presets and parameters, but to no avail. The clips are all .MXF, and it's like FF doesn't work on them at all. I've rendered a crop of the video (mpeg, matched to sequence settings) so that you can see the flickering. I would really appreciate any tips on how I can make this work.
John Pale
Re: How to fix a horrible case of flickering
on Aug 22, 2018 at 12:40:49 pm
No experience with Digital Anarchy’s filter, but the one in BorisFX Continuum package did a wonderful job for me a few years back. Its not free, however.
Pretty sure they have a fully functional time limited trial, though.
Omar Ayoub
on Aug 22, 2018 at 6:41:57 pm
Thank you for your prompt reply. I will give the trial version a shot and update soon. Thanks again!
Ann Bens
on Aug 23, 2018 at 8:38:14 am
I had quite a few of those. Used RE:Vision FX deflicker and did a good job.
Adobe Certified Expert Premiere Pro CS2/CS6/CC
Adobe Community Professional
Kalleheikki Kannisto
on Aug 24, 2018 at 2:43:02 pm
I've had great success with Re:Vision DeFlicker as well. Not a fast process, though. Expect one hour of processing per minute of footage. Five hours of footage could take weeks to chew through at that rate. Better lock down an edit first to see what actually needs to be processed.
Senior Graphic Designer
Omar Ayoub
on Aug 24, 2018 at 8:30:44 pm
Thank you for your reply. You're absolutely right about locking down the edit first. As for FF, it didn't work for me unfortunately, and I even reached out to Digital Anarchy and they told me that it wouldn't work in my case specifically (because it's slow banding and not the typical fast flicker). I also gave BorisFX Flicker Fixer a try, and it didn't work either. My only option is to create adjustment layers over the area of the flicker and keyframe them to match the movement.
John Pale
on Aug 27, 2018 at 12:00:54 am
If you want to post a clip I can download someplace, i can see if I can find a good setting on the Boris Filter. Probably need at least 5-10 seconds to make a go of it. For what its worth, the cropped image you posted doesn't look as bad as what I fixed with Boris a few years ago. Hard to tell, though.
on Aug 27, 2018 at 6:54:42 am
Here's how Re:Vision DeFlicker result from your cropped footage looks. Pretty extreme settings, 8-frame window, meaning the plugin looks back and forward 8 frames for a total of 16 frames to determine the result. Almost 6 minutes render time for 9 seconds of cropped footage, so one second of full footage is about 1 minute of render time (actual speed depending on system specs).
12672_12662deflickersequence.mp4.zip
Omar Ayoub
on Sep 19, 2018 at 5:47:30 pm
Hey Kalleheikki,
Forgive my late reply (I've had some pressing personal matters).
That is amazing! The fact that you got rid of the flicker is amazing to say the least, especially when professionals from Re:Vision and BorisFX couldn't crack it. I don't really care about the render time, I'll do what it takes to fix it. Can you please let me know which Re:Vision plugin you've used (DEFlicker Auto Levels, High Speed, or Time Lapse)? If you can send me a screenshot of the plugin specs you've used I would be forever grateful.
on Sep 21, 2018 at 2:48:02 pm
Hi, fortunately I wrote it in the file description ☺
DeFlicker High Speed, Time Window 8, Coarse Color Match, Large Scale
Omar Ayoub
on Sep 24, 2018 at 5:08:23 am
Thank you so much!
Omar Ayoub
on Sep 24, 2018 at 5:46:10 am
If I could afford it, I would send you the latest Tesla Model S as a token of my appreciation 👍
on Sep 24, 2018 at 10:10:20 am
I take those settings worked for you. The one thing I wasn't sure about is what happens if the person starts moving around too much too fast, there may be "ghost" shapes showing up. If that happens, you can probably compensate for it with the refine settings.
