Rendered preview files don't refresh when dynamic link is refreshed
Mathias Kalhauge
on Aug 21, 2018 at 10:11:00 am
I've been having some issues with a project that's using dynamic links.
When I change something in AE, the files usually update. But I've been having some issues with one file, that doesn't.
First I thought it was a problem with dynamic link, but it seems to be a problem with Premiere Pro not updating the rendered previews. When I look at the file in the source monitor, it has been updated, but in my timeline, it has not.
I've tried rendering again, but Premiere won't let me. The file has already been rendered.
I've linked an image so you can see what I'm talking about:
(The change is a subtle glow to the text. Both the source monitor and timeline monitor are at the same place in the clip)
Is there are way to force-render a sequence?
Todd Perchert
Re: Rendered preview files don't refresh when dynamic link is refreshed
on Aug 22, 2018 at 7:06:52 pm
Try deleting your preview renders. Under Sequence file menu, select Delete Render Files. You can also place an in/out and delete in to out if you don't want to delete all renders.
TC
