Long render time
John Johnson
Long render time
on Aug 17, 2018 at 7:41:12 pm
For some reason, when i added black video and 2 effects to it ( circle and write on and i didn't even use them that much ) , my system got heavily loaded, it took me 5 minutes to render a 5 seconds video. I have added nothing else to that length in my sequence . To compare, effects like lens flare took less than 30 seconds to render on about same length. Is this normal?
Simeon in 't Veld
Re: Long render time
on Aug 29, 2018 at 9:36:19 pm
You can try to recreate the effect in after effects instead and link the after effects file to your premiere sequence. see if that speeds things up.
Joe Barta IV
on Sep 5, 2018 at 3:30:03 pm
Turn off Maximum Bit Depth and Maximum Render Quality in the Sequence Settings.
Joe
Living the SuiteLife!
Stuff for editors http://www.cafepress.com/suitelife
http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
