Raw green screen footage has frame drops / stutter
Arif Mitha
on Aug 16, 2018 at 9:37:40 am
Hello, I am having an issue where if I import raw green screen footage into premiere I have a horrible stutter or lag in the video. I have tried all of the following solutions so far:
Memory setting
Reducing video playback quality
Turning off FX
Changing the project settings
Changing Mercury
Changing the sequence settings
Rendering the sequence
All of these did not help resolve the issue, and this is happening regardless of what camera I use. I just tried it with 4 different cams and the stutter exists in all of them inside Premiere.
Daniel Waldron
Re: Raw green screen footage has frame drops / stutter
on Aug 16, 2018 at 4:07:40 pm
What are the footage specs and what are your computer specs?
Arif Mitha
on Aug 16, 2018 at 10:47:37 pm
MIR (Gaming PC)
Corsair Graphite Series Black 730T Full Tower Case
MSI X99S SLI PLUS ATX DDR4 NA
Intel Core i7-5930K Haswell-E 6-Core
G.SKILL Ripjaws 4 series 32GB DDR4
ASUS GTX980 GPU
Corsair Hydro Series H110 Liquid cooler
Toshiba 3.5-Inch 2TB 7200 RPM HDD
Corsair AX860i Modular 80 PLUS Platinum PSU
2x SanDisk Ultra II 240GB
Monitors: 3 27" BenQ GW2760S
Sputnik (Streaming PC)
Footage running off an SSD
Footage specs:
i attached a pic of the video stats, idk why it says 1k FPS it was recorded at 60
John Pale
on Aug 17, 2018 at 12:04:04 am
Something is messed up with the metadata in he file. You need to tell Premiere not to pay attention to it.
Right click the clip in the Project window.
Select “Interpret Footage”.
Change it to 60fps, or 59.94 fps (Thats more common).
See if it plays better.
Daniel Waldron
on Aug 17, 2018 at 1:19:25 pm
I would also convert your footage to DNxHD or ProRes, which is easier for Premiere to handle.
Jeff Pulera
on Aug 17, 2018 at 3:43:48 pm
Premiere doesn't care if your footage is of a green screen or is regular video, so being green is irrelevant to the playback issue. Rather, please tell us what is the footage? What kind of clips from what camera?
As mentioned, the 1000fps thing is bizarre, so tell how the footage originated and that will help us to help you.
Jeff
Jeff Pulera
Safe Harbor Computers
Arif Mitha
on Aug 18, 2018 at 2:04:56 am
ok sure thing.
I am making a video comparing logitech webcams, I recorded footage of me infront of my GS for each camera, the videos were recorded using Open Broadcast Software, at a 10k bit rate, 1080p 60 fps, setting. I also recorded some other footage using a Canon R700 camcorder in the exact same spot.
The files were recorded using MKV and then remuxed to Mp4. If i key out the green screen in obs before recording the footage plays fine in premiere. But if i leave the GS in, the videos lag in playback.
The clips are all of me sitting in a chair and just talking. Nothing complex, and the room is well lit.
