Effect of Cosmo II plugin is not seen in exported video
Jirka Mucha
on Aug 13, 2018 at 1:53:47 pm
Hello,
When I work with Cosmo Magic Bullet plugin I can see the result clearly during playback in Premiere, however when I export the video the effect is not applied in the exported video.
Todd Perchert
Re: Effect of Cosmo II plugin is not seen in exported video
on Aug 13, 2018 at 7:05:13 pm
Not sure if this will help, but worth a try. In your Project settings, General tab, try changing your Renderer to Mercury Playback Engine Software Only. See if that helps.
TC
Jirka Mucha
on Aug 14, 2018 at 9:48:40 am
Thank you for your advice. I already have this settings.
