One project into multiple projects
Michael Tesh
on Aug 7, 2018 at 4:15:46 am
I don't know if you could always open multiple projects in Premiere at the same time or if this is a recent addition, but I just found out about it and have been using it and it's great. That said, I have a couple older clients where all of their video projects exist in one (for each client) massive Premiere project file. I had simply created one Premiere project and inside of that, a folder of each video (sub) project I did for them.
Is there an easy way to split each of these (sub project) folders into their own project files or is it just a matter of duplicating this one project file multiple times and then opening each up and deleting all but one (sub project) folder from each?
Jamie Pickell
Re: One project into multiple projects
on Aug 7, 2018 at 4:33:05 pm
Yes, you can export folders or sequences as their own Premiere Pro project files. Select the folder or sequence that you want to be its own project and then go File > Export > Selection as Premiere Project and a Save As window will open.
Jamie
Michael Tesh
on Aug 9, 2018 at 3:03:02 pm
Thank you so much. That helps a lot.
