Multi Cam Sync Hell!
Austin Steele
on Aug 3, 2018 at 6:35:18 pm
Every time I sync 2 cameras in Premiere using the Multi Cam Sync function, I get issues. In this case, a Sony a7sII and Sony fs7. Some of the 2 camera shots sync fine. Others sync and combine 4 different shots together. So I get a multi cam clip with 4 different angles, 2 that don’t match. Sometimes I only get one camera to sync even tho I shot 2 camera.
Basically, 1/2 the time something is screwed up and just weird. I realize it could be audio, but we clap synced almost all our shots so that really shouldnt be an issue.
Any ideas ?
greg janza
Re: Multi Cam Sync Hell!
on Aug 3, 2018 at 9:05:39 pm
Do you have problems if you make use of your clap sync and sync using in point?
Windows 10 Pro | i7-5820k CPU | 64 gigs RAM | NvidiaGeForceGTX970 | Blackmagic Decklink 4k Mini Monitor |
Adobe CC 2018 |Renders/cache: Samsung SSD 950 Pro x2 in Raid 0 | Media: Samsung SSD 960 PRO PCIe NVMe M.2 2280 | Media: OWC Thunderbay 4 x 2 Raid 0 mirrored with FreeFileSync
Austin Steele
on Aug 3, 2018 at 11:12:26 pm
Do you mean by doing a manual sync? No that works fine. Just time consuming.
greg janza
on Aug 4, 2018 at 4:49:46 pm
maybe provide some screen capture images to clarify your problems.
I've never run into any syncing issues with multicam so your problems are a bit confusing.
