Syncing video to master audio clip
John Watts
on Aug 3, 2018 at 9:16:38 am
Very new to Premiere...well..at least after 15 years.
When I use synchronize the audio clip wants to adjust to the video.
However, I need the video layers (10 camera angles) to synchronize to the master audio track.
Am I just dreaming as I edit at 4AM??
Could this be possible?
John Watts
greg janza
Re: Syncing video to master audio clip
on Aug 3, 2018 at 3:09:06 pm
Do all of your video angles have audio as well? If so, just highlight all of your video angle clips as well as the master audio clip and then control click and select "create multicam source sequence" and synchronize using audio.
If you don't have syncable audio for each video angle you'll need to find a sync point for each angle and then within "create multicam source sequence" select synchronize using mark in.
Windows 10 Pro | i7-5820k CPU | 64 gigs RAM | NvidiaGeForceGTX970 | Blackmagic Decklink 4k Mini Monitor |
Adobe CC 2018 |Renders/cache: Samsung SSD 950 Pro x2 in Raid 0 | Media: Samsung SSD 960 PRO PCIe NVMe M.2 2280 | Media: OWC Thunderbay 4 x 2 Raid 0 mirrored with FreeFileSync
