Distorted audio when burnt on BD
Vasco daNeva
on Jul 27, 2018 at 1:06:43 pm
I’ve made a dozen 2 to 3 hour films of family trips abroad. First on DVD then Blu Ray. All on Premiere Pro. From CS3 to CC2018. All with Voice Over. The Voice Over is done on Audition with the ENDN formula (see https://www.youtube.com/watch?v=6x__NthInRs) Equalize, Normalize (98.5), Compress, Normalize (98.5). The last film I did sounds great on a computer with or without headphones. But when I play the BD on a TV the sound is very loud and quite distorted, especially the Voice Over. I encoded a version with gain lowered by -5. Result - same thing, only quieter. Rendered another, minus 10 Audio Gain this time. Quieter, but when you turn up the TV volume so you can hear what’s going on, it’s distorted again. I am not sure if “distorted” is the correct word in English, it sounds like when you’ve recorded something with peaks high in the red.
I tried the project’s sound on several different computers. All sounds good off the computers. And what is important!!! all sounds like it did on previous projects I made. It is only the DVD and BD (I tried both) that sound horrible. Like I said, I’ve made many films and never had this problem before.
I have to stress on the fact that I don't hear any problems before I burn the BD. So I don't know hwat to correct, let alone how to correct it. Can somebody advise what to do to the audio? Simple terms please, I am not good with audio at all.
Thank you!
Vasco
Chris Wright
Re: Distorted audio when burnt on BD
on Jul 30, 2018 at 2:23:54 am
narrow down the problem to either audio settings, codec, or tv. try a normal bs1770 preset in audition first.
Roger Averdahl
on Jul 30, 2018 at 3:18:09 pm
How do you export from Premiere Pro and what version do you use? Can you upload a sample so one can hear what how it sounds?
Too much compression can make the audio to sound "kind-of-distortion-ish". Also, using audio from footage/music and add a voice over require a hard limiter on the master track to limit the output to avoid issues.
