Holding "stable" wb setting in footage form multiple devices
Andrew Rabka
on Jul 26, 2018 at 3:38:00 pm
Could anyone give me a tip where look for tutorials/books/materials ect. which allow correct, badly recorded footage?
I have used canon 5d II and lumix g80. There are a lot of scenes which have mismatched white balance setting. Every tutorial which I have seen is about correcting something what doesn't need correction at all in my opinion.
The point is, I have cut 40 minutes movie and now I want correct it one clip after another. Effect which interest me is getting "stable" colours in whole material. Now
when I am trying to do it, the effects is not constant. For example in first 2 minutes everything is ok - human eye can't see differences between following scenes, but when I compare 2 an 20 minute of movie there is a huge mismatch. How to prevent it?
Thanks in advance
Chris Wright
Re: Holding "stable" wb setting in footage form multiple devices
on Jul 26, 2018 at 4:33:09 pm
is it changing every 2 seconds or every 5 minutes? something slower you could keyframe white balance and fade between the clips so its gradual or cut adjustment layer and use dissolve.
something changing every 2 seconds would require AE unless there is an auto color stabilizer for premiere.
Dave LaRonde
on Jul 26, 2018 at 8:03:22 pm
If all the shots in a scene have the identical bad white balance, you can correct one, then copy & paste attributes to the others. Work your way through scene-by-scene.
Dave LaRonde
Promotion Producer
