have to re-link proxies every time Premiere is launched
Julie C
on Jun 27, 2018 at 9:32:23 pm
Every time I open premiere, I have to manually relink the proxies. Anyone know how to get Premiere to remember where they are?
Jon Doughtie
Re: have to re-link proxies every time Premiere is launched
on Jun 28, 2018 at 3:42:59 pm
Where are original footage/proxies stored? What version of Premiere Pro? What OS?
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2017.1 (as of 8/2017)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
Julie C
on Jun 29, 2018 at 2:18:38 pm
Most recent versions of all ... High Sierra 10.13.5, and PP 12.1.1.
The folder with the proxies are on the same drive as the source footage, but everything was moved (consolidating drives for a second editor) which triggered the problem.
Thanks.
Luke Sheldon
on Jul 12, 2018 at 2:46:03 pm
Same problem. Did you ever solve this? Thanks.
Debbie Elbin
on Jul 23, 2018 at 8:05:06 pm
If you save your files when you close it, even if you did no work on the project, it will remember the links and you wont have to re-link next time.
Jason McKee
on Oct 26, 2018 at 2:22:58 am
I'm having this same issue and it does not remember that I relinked them after saving.
Graham Withers
on Oct 31, 2018 at 6:49:46 pm
Saving at close tends to work for me but I've definitely had this problem on previous projects. Sometimes different sets of proxies needed to be relinked at each start up.
I thought it might be a case of similarly named clips in different folders but never really got to the bottom of it - so I'm following along.
