DCP-O-Matic/Premiere Output Gamma settings for 4k file
Adam Levine
on Jun 26, 2018 at 12:24:36 am
I'm using DCP-O-Matic 2 to create a DCP from a ProRes file of a 4k feature that was graded in and output from Premiere Pro CC2017.
In DCP-O-Matic's output options, under "Colour conversion," it's my understanding that (for a Premiere export) Input Gamma should be set at 1.8, but at the bottom of that window, there is also an option to "Inverse 2.6 gamma correction on output". This is checked by default, but I'm wondering if anyone here knows what this actually means. Do I leave it alone or uncheck it?
Thanks so much!
Tero Ahlfors
Re: DCP-O-Matic/Premiere Output Gamma settings for 4k file
on Jun 26, 2018 at 3:53:33 am
The input gamma should be the gamma that your file is graded in eg. if your color pipeline is gamma 2.2 then use 2.2.
Adam Levine
on Jun 26, 2018 at 7:03:04 pm
Thanks so much! I'm still wondering about the "output gamma" option, though. Do I want choose to "Inverse 2.6 gamma correction on output" if my input gamma is 1.8?
