Proxy workflow with merged clips
Mimi Wilcox
on Jun 9, 2018 at 6:07:06 pm
Hi there,
I’m about to launch into a feature doc edit in Premiere and want to make sure I’m thinking about my proxy workflow in the correct way. My primary question is about how merged clips function when using a proxy workflow. The producer has created merged clips using the original raw video to connect it with audio recorded externally. Do proxies need to be created & attached prior to merging clips, or can they be created & attached after the fact? Should I anticipate any issues with reconnecting original media down the road when using merged clips & proxies? I want to be sure to avoid any mismatched audio channel issues.
Hope this makes sense. Thanks very much.
Graham Withers
Re: Proxy workflow with merged clips
on Jun 13, 2018 at 6:57:53 pm
I'm listening in here as well Mimi - I'd love to get a handle on a better merged clip/proxy workflow for doc work.
Michael Paulucci
on Aug 23, 2018 at 8:48:05 pm
Did anyone ever get an answers for this or figure it out?
Toby Wilkins
on Oct 31, 2018 at 4:37:32 pm
According to this replay from Adobe back in Jan 2017 ( https://forums.adobe.com/thread/2269593 )
"Merged clips are not currently supported for Proxy. Please fill a feature request form."
greg janza
on Oct 31, 2018 at 6:15:03 pm
You should never be using the merged clip function. Adobe should remove it as a feature. Instead all syncing should be done with Multicam. Merged clips is a destructive action and Multicam is not and so only with Multicam can you match frame back to your original material.
Windows 10 Pro | i7-5820k CPU | 64 gigs RAM | NvidiaGeForceGTX970 | Blackmagic Decklink 4k Mini Monitor |
Adobe CC 2019 13.0 | Renders/cache: Samsung SSD 950 Pro x2 in Raid 0 | Media: Samsung SSD 960 PRO PCIe NVMe M.2 2280 x 2 | Media: OWC Thunderbay 4 x 2 Raid 0 mirrored with Resilio
Mimi Wilcox
on Oct 31, 2018 at 6:26:13 pm
FWIW for those asking, I wound up using the suggestion from this article:
https://blog.frame.io/2018/05/14/premiere-batch-syncing/
which explains that you must create and attach proxies prior to merging clips. Worked smoothly.
Graham Withers
on Oct 31, 2018 at 6:42:19 pm
Great link Mimi - thanks. Super useful breakdown of proxy/syncing workflow!
If anyone's come across similarly awesome workflows with Premiere - I need to draft a similar breakdown for documentary editing for both my own work and for conducting workshops.
Bouke Vahl
on Oct 31, 2018 at 9:38:03 pm
Perhaps I've scanned the page too quick, but I miss the 'batch' part if you have to touch each and every clip.
What am I missing here?
Bouke
http://www.videotoolshed.com
Graham Withers
on Oct 31, 2018 at 9:59:18 pm
Once you've imported, renamed and selected all the clips in the bin, it'll "batch" sync them all, no?
Bouke Vahl
on Oct 31, 2018 at 10:07:34 pm
No. You end up with a sequence per clip that you have to open, select tracks and then merge.
For me batch syncing means pointing to video and audio, select the tracks you want as an option, then sync and end up with all clips. NOT touching all clips.
Not a big deal for a few clips, but if you have dozens or hundreds...
Bouke
