Is this a Quicktime issue?
Kalleheikki Kannisto
on Jun 6, 2018 at 9:56:35 am
Hi guys,
As of about 2-3 weeks ago, I have not been able to convert a .mov (animation 100% quality) of over 2GB file size in Media Encoder to H.264, not even by bringing the video in to Premiere and exporting it from there in H.264 format. The video stops at around the 2GB mark and renders a still image of that frame for the rest. Does anyone know if this is related to the end of Quicktime support or something else? Never had this problem before, it just recently appeared. Same issue in both AME CC2017 and CC2018, Windows.
Which leads to the question: Is DNXHD my next best option for high-quality (near lossless) intermediate output for Full HD with audio?
Senior Graphic Designer
Tero Ahlfors
Re: Is this a Quicktime issue?
on Jun 6, 2018 at 10:28:43 am
I've used DNxHR or Cineform depending on what I need to do. Cineform supports weirder resolutions eg. if you're doing vertical videos.
on Jun 6, 2018 at 11:15:42 am
Thanks Tero, I'll look into using those instead. I am quite in the dark about what the issue about "Quicktime support ending" means in practice. I thought Quicktime is a container format, not an encoding format, so what's that got to with the price of fish? For example GoPro Cineform options are under Quicktime presets, so I would expect it to still export a .mov file, right? I guess I'll have to do some testing with a variety of file formats to see if that is even the issue.
Tero Ahlfors
on Jun 6, 2018 at 11:24:32 am
[Kalleheikki Kannisto] "I am quite in the dark about what the issue about "Quicktime support ending" means in practice"
Apple stopped developing Quicktime so instead of keeping on using the 32-bit not-secure legacy stuff developers have made their own Quicktime decoders/encoders. This means dropping support for some of the older codecs.
https://helpx.adobe.com/x-productkb/multi/quicktime7-support-dropped.html
on Jun 6, 2018 at 11:35:15 am
Ok, I see. Animation codex isn't even affected by this. Sounds like time to look for different cause for the problem.
Chris McLaughlin
on Jun 8, 2018 at 5:58:29 pm
Are you rendering out to a new drive? Possible that the drive format is FAT16...2GB file size limit there.
on Jun 9, 2018 at 5:36:07 am
The drive is NTFS formatted. It seems to only affect Quicktime with Animation codec (that I've noticed so far). Other codecs are working fine with over 2GB file sizes. This also happens on exporting a file from Premiere (both CC18 and CC17) to that format. Haven't done any extensive testing to determine if it is a consistent problem, it seemed more sensible to switch formats than to get stuck on it. Just wondered if anyone else had run into the same issue recently.
Christopher Smith
on Jun 26, 2018 at 4:44:54 pm
[Kalleheikki Kannisto] "Just wondered if anyone else had run into the same issue recently."
Yes, indeed. We're having many problems with Premiere and AME, especially in the past month, even though nothing changed in the software we have installed in our suites. We're not even running High Sierra yet, but in the past month, Animation codecs have stopped working, and other glitches have appeared.
It is particularly frustrating and puzzling as no software has been updated. Videos in animation codec which I try to transcode to M2V for DVD production are stopping in the AME queue after encoding (the task doesn't ever finish on its own and move to the next task), although the video does encode. IOW animation codec videos transcode, get stuck at the very end of processing, and I must stop the queue (check "No, please don't finish.") and restart the queue to transcode the next video.
So, without changing our (editors) software, somehow Adobe has broken Animation codec. My only guess is that the Graphics department made a change to their software, so their Animation codec videos are now defective.
Note that Animation codec is not on Adobe's list of deprecated codecs.
Christopher Smith
CBN International
