Video won't play after render
Kevin Peters
on May 17, 2018 at 12:55:42 am
I have been working on a short film which I have rendered out many multiple times before without any problems but now all of a sudden when I render my sequence the file will not play in quicktime or vlc. The file doesn't have a thumbnail like they did before which is the tail tail sign it's not going to play.
Nothing in the way of new/changed clips would be the cause so it's really weird.
I tried to create a new sequence and copied the clips into it but still no luck. If I render out half of the time line and then the other half it works fine so i'm baffled.
Render settings
h.264
1920x800
vbr, 2 pass
14 / 16
render at max depth checked
would love some help
Mike Jones
Re: Video won't play after render
on May 17, 2018 at 12:51:51 pm
Kevin,
Are you trying to render or export?
A few things to try in trouble shooting if you are trying to export:
Did you try exporting 3/4 or your video?
Did you try exporting all but the last frame?
Did you try exporting to another codec?
