Informal Survey: Where is your project file in relation to your media & assets?
Ben Howard
on May 16, 2018 at 7:53:27 pm
Hive mind question: where do you save your project file vs. the media and assets for your Premiere projects? All on the same drive? Project on a different drive than media?
(Researching the cause for some recent crashes & I suspect the old workflow we've been using - all on 1 drive - may be causing problems. Over the years I've done both without noticeable impacts - except when using FCP7. My recent switch back to Windows has me curious if things need to change.)
Ben Howard + buttonpusher.tv + twitter: buttonpusher
Editing - Consulting - Workflow - Asset Management
greg janza
Re: Informal Survey: Where is your project file in relation to your media & assets?
on May 16, 2018 at 9:16:25 pm
Project file on media drive
backup project file on Google drive
media cache on cache / render drive
Windows 10 Pro | i7-5820k CPU | NvidiaGeForceGTX970 | Blackmagic Decklink 4k Mini Monitor |
Adobe CC 2018 |Renders/cache: Samsung SSD 950 Pro x2 in Raid 0 | Media: Samsung SSD 960 PRO PCIe NVMe M.2 2280 | Media: OWC Thunderbay 4 x 2 Raid 0 mirrored with FreeFileSync
Scott Fleener
on May 17, 2018 at 7:46:33 pm
Project File : On Main Hard-drive
Assets : On external hard drive
If its business related everything goes on Google Drive
Todd Perchert
on May 18, 2018 at 6:36:45 pm
I keep project and media on fast external array. Everything together, easy to archive.
TC
Al Davis
on May 20, 2018 at 3:17:08 pm
The application on my main internal drive (obviously).
Project on a different internal drive.
Assets on an external drive (fast!)
Sometimes render files on a different (fast) external drive.
Why? You don't want a spinning drive doing multiple functions (like running the app and the system while also processing your project file) as it slows it down.
On a complex project (in AE) I sped up an output from 19 hrs. down to an 90 minutes once I spread everything out to 4 different drives.
I have an older (put pretty fast) mac pro.
Al Davis
Visual Velocity
Brookline, MA
