Intermittent Playback Stutter - Premiere CC 12.1.1
Bob Thompson
on May 4, 2018 at 12:35:25 am
I am editing footage from a Phantom 3 Pro quadcopter - 1080p 59.94.
Most of the time, not always, the footage is jerky or stuttery when I play it in the source or program window. I know it's h.264 long gop and should optimally be transcoded etc. but this has recently started. My system should be powerful enough to play 1080p. I have a Samsung 950 NVME for program files and cache and my footage is on 2 internal drives in raid 0.
Resolve plays the footage perfectly. VLC plays the individual clips perfectly. Premiere is the only program that has problems. I'd move to Resolve permanently but I use After Effects too much.
Has anyone else experienced this? Know what settings I might change?
Win10 64bit | ASUS X99-AII | i7 6850K @ 3.60GHz | 32GB Ram | GeForce GTX 1080 | DeckLink Mini Monitor 4k
Thomas Hanser
Re: Intermittent Playback Stutter - Premiere CC 12.1.1
on May 5, 2018 at 12:10:25 am
I'm having similar problems with Premiere Pro 2018 on a Dell Precision T3600, plenty of RAM and VRAM. I've changed some settings in Premiere based on some suggestions found all over the Internet, but playback performance hasn't improved at all. I can't work like this!
I've tried working with different clips from several different cameras - no change. They all play back jerky in the timeline. Even the audio is jerky.
All of these clips play back fine in QuickTime or VLC.
Source files on a separate, physical HD, not the OS drive.
Playback resolution is set to 1/2 or 1/4. No change.
Renderer is set to CUDA. No change.
Renderer is set to Software. No change.
What else?
Thomas Hanser
Seattle, WA
Thomas Hanser
on May 5, 2018 at 12:39:11 am
Just found it!!!
I went into Edit > Preferences > Audio Hardware and then changed Default Input to "No Input." It was set to the input of my sound card, which currently has no device plugged in to it. Not sure why that would cause it, but as soon as I changed this I was able to preview the video file with no stutter in the playback.
Thomas Hanser
Seattle, WA
Bob Thompson
on May 5, 2018 at 9:00:41 pm
Thanks for the reply.
I might have that problem as well, don't know; my footage doesn't have audio.
I thought I had cracked it by downgrading to version 12.0. Played fine yesterday. Today the stuttering is back making Premiere unusable.
I found a tutorial showing how to display dropped frames...hit the wrench icon (on the bottom right of either monitor by the "In/Out Duration") -> Show Dropped Frames Indicator. I dropped 562 frames playing the first 30-seconds of a clip.
Must be a problem with my system since no one else has replied...
Thomas Hanser
on May 5, 2018 at 9:10:01 pm
It has nothing to do with your footage having no audio - I changed this setting and my problem instantly went away.
Thomas Hanser
Seattle, WA
Bob Thompson
on May 5, 2018 at 9:15:59 pm
Thanks.
Forgot to mention my audio settings were set to No Input.
Also stutter happens regardless of playback quality...
Josh Sledge
on Aug 31, 2018 at 11:06:43 am
Oh my god, you're a genius ! I had this problem for months, if not years, you NAILED IT !!! I've just created an account on Creative Cow to thank you ahah
Vlad Star
on Mar 19, 2019 at 6:49:55 pm
Thank you! It worked for me. I was loosing it :)))), but you have saved my day!!!
greg janza
on May 6, 2018 at 5:54:57 pm
[Bob Thompson] "I know it's h.264 long gop and should optimally be transcoded etc. "
You've answered your own question. Premiere simply doesn't like H264 long GOP. Transcode it and you will have no problems.
Windows 10 Pro | i7-5820k CPU | NvidiaGeForceGTX970 | Blackmagic Decklink 4k Mini Monitor |
Adobe CC 2018 |Renders/cache: Samsung SSD 950 Pro x2 in Raid 0 | Media: Samsung SSD 960 PRO PCIe NVMe M.2 2280 | Media: OWC Thunderbay 4 x 2 Raid 0 mirrored with FreeFileSync
Bob Thompson
on May 6, 2018 at 10:19:44 pm
[greg janza] "Premiere simply doesn't like H264 long GOP. Transcode it and you will have no problems."
Thanks.
That's the usual go-to answer so for what it's worth I transcoded a 17:18 clip to DNxHD SQ 8bit. Premiere playback dropped 332 frames. I'm sure it has something to do with my setup since there are not many people chiming in with the same problem...
greg janza
on May 7, 2018 at 4:36:46 pm
Maybe you have a bottleneck with your media drive? Your specs show that you have plenty of power.
Giri Pillai
on Sep 20, 2018 at 2:25:55 am
My issue initially resolved with changing the audio input in hardware preference. Later it came back as I was switiching between my bluetooth headset and Benq monitor audio. (My monitor audio was not working because I changed HDMI to display port cable). So there was no output from benq and I had Realtek HD audio installed, but no external speakers(used plug in earphones, worked for audio, but stuttering present), LOL.
Solutions:---
1) So whenever I use my bluetooth Bose headphone used with "No input"" selected in audio hardware preference no stuttering.
2) I updated Realtek HD driver , no more stuttering
3) Benq display audio , that was my mistake. In Benq Monitor, there is an option to select audio, I set that to Auto""(previously "PC")". Now there is audio (there was no stuttering issue with this audio anytime)
