Last audio hangs
Dorian Weber
Last audio hangs
on May 3, 2018 at 12:01:48 pm
I found a solution:
just add an empty audio file at the end.
Thank you
Dorian
Hello,
I never really worked with audio but this time I make a slideshow and I have a few video clips which have some audio. Strange enough, the last bit of audio keeps on repeating over and over again. Until I have an other audio clip. And then the last bit keeps on repeating over and over again.
On the original timeline I can not find anything wrong, but after I export and transcode it to H.264 it shows.
I really need that slideshow working.
Thank you in Advance
Dorian
Jon Doughtie
Re: Last audio hangs
on May 3, 2018 at 3:13:41 pm
BTW, sometimes compressed audio (for example, MP3) will misbehave in the timeline. I almost always convert to uncompressed audio for the edit.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2017.1 (as of 8/2017)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
Dorian Weber
on May 3, 2018 at 3:52:00 pm
thank you for telling me!
Because the main audio will be MP3 music.
I would appreciate it if you could give me some advice on how and where to change it. I still have Soundtrack Pro.
And if you could give me some settings would be also great since I never worked with audio before.
And this video is very important to me.
Dorian
