Stills jump after Transition
Dorian Weber
on May 3, 2018 at 4:47:00 am
Hello,
I have to make a slideshow from Still Photos in Premier.
Most of the transitions go smooth, but in some the image jumps.
I made a search which said to set the Sequence to No Fields, which I did, but no change.
Mostly I see the jump in a transition: Split and also Center Split (right at the beginning and the end of the transition). I removed all other effects with Keyframes to make sure those are not the cause.
I really like that transition and would like to keep it in. I am using Premier 2015 Release 2.
Any suggestions how I can solve that problem?
Many thanks in Advance
Dorian
