Audio handles when editing an audio file in Adobe Audition
Damian Nossent
on Apr 25, 2018 at 11:18:13 pm
Hi all!
I would like to edit some of my audio in Audition, but when I click on "Edit in Audition", the clip is replaced with the Audition one and I can't roll my audio anymore. After some research I found that's it called "Audio handles".
So what I want to do is: edit a clip in Audition, but keep the full audio length.
I hope someone knows a solution for this.
Damian
Jon Doughtie
Re: Audio handles when editing an audio file in Adobe Audition
on Apr 26, 2018 at 1:23:17 pm
Remember, you do not have to enter Audition through Premiere Pro. You can open it independently, open and work on your file, and save it with a new unique file name. Then close Audition, hop back into PPro and import your new unique media. Original remains untouched.
Some would say that is a rather old-fashioned way to do things. Perhaps it is. It also works.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2017.1 (as of 8/2017)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
Paul Neumann
on Apr 26, 2018 at 1:32:44 pm
You can change the length of handles for rendered clips on the Render and Replace dialogue pop up.
Damian Nossent
on Apr 30, 2018 at 5:27:59 pm
Just an easy work around. Thank you.
