Balancing Right & Left Audio Channels for MTS Video Files
Edward Gilman
on Apr 25, 2018 at 3:34:00 pm
Hello,
I have a bunch of MTS (MPEG Transport Stream) video files and the audio levels are not balanced for Right & Left Channels (see MTS File Format Audio Imbalance image below)
The sound is primarily just coming out of my right speaker and I can barely hear it in the left.
What's the easiest way to balance the R & L channels so I can hear them balanced in both speakers?
Ed
Gary Milligan
Re: Balancing Right & Left Audio Channels for MTS Video Files
on Apr 25, 2018 at 4:24:12 pm
Looking at the image it appears that both channels are exactly the same, but the left is lower than the right - basically a mono track. The easiest way is to apply the "fill left with right" effect. You should find that in your Audio Effects list.
Edward Gilman
on Apr 29, 2018 at 9:43:53 pm
OK, thank you. I'll give that a try.
Edward Gilman
on May 24, 2018 at 7:11:23 pm
Hello, Great advice! It worked perfect. Thank you very much... Have a nice day. ~E.
Ricky Barrow
on Apr 26, 2018 at 11:46:47 am
or import/link with audio settings as individual mono tracks (before editing into a sequence.
Ricky
Edward Gilman
on Apr 29, 2018 at 9:44:33 pm
Thank you but how do I do that?
Ricky Barrow
on Apr 30, 2018 at 11:59:28 am
Preferences\Audio\Set all options to MONO. Then link/Import files. Then place into SEQ/Timeline.
Ricky
Edward Gilman
on Apr 30, 2018 at 9:58:59 pm
Perfect, thanks Ricky!
