Adding a clip to timeline destroys rendered material
Eric Merklein
on Apr 23, 2018 at 8:52:22 pm
I did some grain reduction in After Effects . I rendered the 50 minute ch 1 video, but when I add an edit from another clip the rendering goes away.
Is there a work around? Peas say yes
Many thanks.
John Pale
Re: Adding a clip to timeline destroys rendered material
on Apr 24, 2018 at 12:34:02 pm
Sounds like a job for the “Render and Replace” function.
Todd Perchert
on Apr 24, 2018 at 3:27:11 pm
If you are using Dynamic Link and did a preview render in PPro, then yes, it will go away when you add anything on top of that layer. You may want to render it in AE and bring in the rendered file.
TC
