need your counsel about sequence type
Omar Sleem
on Apr 23, 2018 at 3:03:12 pm
hey guys
hope you all are ok
I need your counsel
I am about to begin a new project, and there are terms of the client:-
___________________________________________________________________
VIDEO & AUDIO REQUIREMENTS:
3. HD Format:
All programmes must be delivered in the following format and in general meet AS11 or DPP standards.
3.1 HD Acquisition and Delivery Format
Note: we broadcast Interlaced video: 1080i50. No progressive video will be accepted.
• 1920 x 1080 pixels
• 16:9 aspect ratio
• 25 frames per second interlaced ‐ known as 1080i50
• 4:2:2 colour sub sampling (Minimum).
__________________________________________________________________________
so, please, tell me what is the best sequence type should I use, in premiere pro, and are there any sections may I modify in the sequence settings??
John Pale
Re: need your counsel about sequence type
on Apr 23, 2018 at 5:21:21 pm
DNX HD - DNX SQ or HQ 1080i50
Omar Sleem
on Apr 23, 2018 at 8:36:45 pm
thanks for your valuable response, John
I have used the XD CAM EX 1080i50(HQ) - check the image in the link below.
may I continue editing in this sequence or switch to one of the formats you mentioned??
John Pale
on Apr 23, 2018 at 8:49:02 pm
That would be fine also. It doesnt really matter. Premiere renders in the format you select for final export. If you are getting decent enough editing performance with XDCAM HD 50, then go with that.
