Google Earth Pro maps: can anyone here make a smooth animation from them?
tad newberry
on Apr 15, 2018 at 12:22:19 am
I know, not exactly a Premiere Pro question, but i'm finding no answers anyway else. I watch the news and see these great and very smooth Google Earth map anims and wonder why i can't get nearly the same result.
One person offered this advice that came close to working: turn off "terrain" when creating a tour, then turn it back on when making the movie.
Any other ideas out there??? I could really use some help on this ASAP.
thanks for helping out a bonehead!
__________________________
FCS3 / Adobe CC
3.33 GHz 6-Core Intel Xeon Mac Pro
24GB RAM
ATI Radeon HD 5870
...and a few TeraBytes o' storage
(then it's on to PetaBytes, ExaBytes and MosquitoBytes!)
Dave LaRonde
Re: Google Earth Pro maps: can anyone here make a smooth animation from them?
on Apr 16, 2018 at 11:53:14 pm
Now, mind you -- I wouldn't attempt such a thing in Premiere Pro; it's for editing.
I'd use After Effects; it's for making animations.
That said, probably the biggest influence on smooth moves in an animation is the frame rate; the higher the frame rate, the smoother the motion. Next comes the speed of the moves; fast moves are rarely smooth ones.
I don't know if PP has Motion Blur in it, but if it does, you can try it, too. And use Bezier keyframes to ease in and out of moves.
Dave LaRonde
Promotion Producer
Shane Ross
on Apr 17, 2018 at 1:52:15 am
If you plan on using Google Maps animations for video use, you need to get the PRO version (cost $$), and license the map animation from them...or maybe that's what the PRO does...and you need to make sure their watermark is visible (no scaling to crop it out). At least this was the case 8 years ago. Gotta check with Google on this. Also, make sure you have a powerful enough machine...it might be a processing issue. Or browser, try different browsers. BUT...if licensed and you have the PRO, you would be able to export the map move as a QT...
Shane
Little Frog Post
tad newberry
on Apr 17, 2018 at 2:25:55 am
Ya, thanks. The $400 annual fee went away a couple years ago, which is nice, and using their Movie Maker seems to be the weak link in the chain. I can get several seconds of smooth-as-glass moves, and then it will hiccup. Very frustrating.
FCS3 / Adobe CC
24GB RAM
ATI Radeon HD 5870
