Unwanted Pre-set in out points in source monitor
Eric Merklein
on Apr 9, 2018 at 2:52:36 pm
Since I first started using Pro last year, I've had the same issue when I first open a source in the source monitor.
There is always a 5 second in/out point already there, and I have to delete them in order to make an edit. Drives me crazzzzy.
Is there a fix? It's been there one very version of Premiere Pro.
thanks for any guidance on this.
Eric
Many thanks.
Todd Perchert
Re: Unwanted Pre-set in out points in source monitor
on Apr 9, 2018 at 7:11:24 pm
It sounds like PPro is using the default time for still images as your default for footage. Because I've never seen anything like that except on still images. That is a PPro preference. I would try trashing the preferences, see if that helps.
Good Luck!
TC
Eric Merklein
on Apr 9, 2018 at 7:14:22 pm
Hi Todd. I did trash pref's but no help at all.
Thanks for getting back to me.
Eric
Many thanks.
