AVOID 12.1 update!
Dan Powers
AVOID 12.1 update!
on Apr 5, 2018 at 5:58:59 pm
It has big issues!!
Dan Powers
Re: AVOID 12.1 update!
on Apr 5, 2018 at 6:06:26 pm
Files with alpha channels are coming in corrupt. From Support "This is a bug that we have logged for the Premiere pro, it is happening with the PNG files as well as any mov file with the transparency (alpha channels) the workaround here is to revert to the older version"
Robert d'Alexis
on Apr 5, 2018 at 7:27:34 pm
Works fine here with a .mov file using the Gopro Cineform 12-bit with alpha codec.
I am on Windows 10 and I can assure you that I have no issue encoding and importing the above-mentioned file.
I suggest you try similar files and report back.
Robert d'Alexis
on Apr 5, 2018 at 10:38:56 pm
[Dan Powers] "it is happening with the PNG files as well"
I have been testing PNG files and I can report that they work just fine in an HD timeline.
Maybe your issues are Mac-related as I am on Windows 10.
Anyone else care to chip in?
Ann Bens
on Apr 6, 2018 at 9:01:45 am
Try this:
Modify -> Interpret Footage.
Under the Alpha Channel category, select "Conform Alpha Premultiplication To:
And also select the box: Premultiplied Alpha
Adobe Certified Expert Premiere Pro CS2/CS6/CC
Adobe Community Professional
Michael Sacci
on Apr 9, 2018 at 5:44:33 pm
"the workaround here is to revert to the older version"
How does one revert to 12.0.1? there is no way to not have 12.1 overwrite the older 12 versions.
Michael Sacci
on Apr 9, 2018 at 5:49:48 pm
Never mind, I see that it has 12.0.0 listed in the previous versions drop down.
David Busse
on Apr 5, 2018 at 7:53:05 pm
Agreed! Mine wouldn't even open. After 1.5 hours of troubleshooting, uninstalling, reinstalling I was able to get back up and running by downgrading back to 12.0.1
Video Producer/Editor
http://cidesigninc.com/
Todd Hallam
on Apr 5, 2018 at 8:14:32 pm
Agreed! Major slowdowns - and Adobe Typekit keeps trying to resolve a conflict even though I have it shut off in CC. Spinning beachball trying to resolve that and xml imports given me lengthy beachballs. HUGE timewaster!!!!!
Todd Hallam
SideshowFX
http://www.sideshowfx.net
Christopher Paul
on Apr 5, 2018 at 8:53:54 pm
Yup. Another issue is that the search fields no longer work- greyed out.
Robert d'Alexis
on Apr 5, 2018 at 11:03:35 pm
[Christopher Paul] "Another issue is that the search fields no longer work- greyed out."
They work just fine here.
Ann Bens
on Apr 6, 2018 at 9:26:13 am
This help a user:
Dan Pearce
on Apr 6, 2018 at 9:44:55 am
Two hours in and so far...
It wouldn't open, had to delete the "Typesupport" folder to get it working (which maybe explains the following problems)
Wrench icon (timeline display settings) doesn't work!
The Editing Mode drop down in sequence settings doesn't work!
Format drop down in Export Settings doesn't work!
Anyone else having these issues!?
Not impressed ]
Dan
Oliver Peters
on Apr 6, 2018 at 1:27:49 pm
Is this a Mac or Windows issue? If so, are you running the latest OS? So far, I've updated at least 8 Macs (various models) without issue, other than a few minor glitches here and there. Nothing outside of the ordinary.
- Oliver
Oliver Peters - oliverpeters.com
David Busse
on Apr 6, 2018 at 2:58:31 pm
Oliver,
I am having this problem on a 2012 iMac and a 2014 iMac. On a 2013 MacBook Pro it was working fine. We are now running all on 12.0.1
Also, FWIW had a problem where XML from Premiere 12.1 from our laptop wouldn't work in 12.0.1 so I sent the XML to Premiere 2017 and it opened in there then I was able to update that project to 12.0.1
Dan Pearce
on Apr 6, 2018 at 3:09:49 pm
Mac Pro (Late 2013). It's a production company who are still running 10.11.6 because of a server requirement.
Exported an xml and rolled back to 12.0.1 as I had work to do.
Don Daedalus
on Apr 18, 2018 at 5:54:41 pm
MASSIVE PROBLEMS on Premiere 12.1:
-.mov with alpha channels flicker, glitch
-Some .mp4 videos appear upside down
-Exporting FCP XML, fail upon importing to 12.0
Downgrading to 12.0 has problems also:
-Exporting .H264 renders "Error compiling movie -> Import Error -> importer returned bad result
-importing XMLs from 12.1 creates an error
-Starting a new project and dragging XML has some results, but creates problems upon exporting
-AME 12.0 fails
-Missing audio filter/video filter depending on whether AU or AE are upgraded/downgraded.
At least Adobe is admitting these problems exist, (search tag '12.1')
https://forums.adobe.com/search.jspa?q=12.1
Macbook pro 2017, High Sierra, 16GB ram, Intel 3.1 i7
-DHPD
Alan Okey
on Apr 19, 2018 at 5:44:34 pm
Premiere Pro CC 12.1.1 has been released.
Release notes:
Bugs fixed in April 2018 (version 12.1.1) release
The following bugs are fixed in version 12.1.1 release of Premiere Pro:
· Fixed a crash on launch in some cases when loading Cool Type fonts (these fonts are prevented from loading.)
· PNG files containing Alpha are correctly displayed with the default interpretation of Straight Alpha.
· In some PNG frame sequence exports, frames no longer get mixed together (superimposed).
· Application no longer hangs if you quit it after playback of Sony F5 RAW files.
Todd Hallam
on Apr 19, 2018 at 8:41:52 pm
Great - still hasn't fixed the biggest issue of all mp4 media reading as offline though.
Todd Hallam
SideshowFX
