Audio is way out of sync with the video
Skylar Sweat
on Apr 2, 2018 at 1:10:17 am
There is what sounds like a 1 minute maybe a 30 second delay, in my UnderTale let's play video that i am working on editing in Adobe Premiere Pro, Is there possibly a way to fix it?
I am hoping to get this uploaded today if possible.
Ann Bens
Re: Audio is way out of sync with the video
on Apr 2, 2018 at 8:14:33 pm
If this is screencapture footage you need to convert to Constant Framerate with Handbrake to get it back into sync.
Although 2018 support variable framerate it is not always reliable.
http://handbrake.fr/
Adobe Certified Expert Premiere Pro CS2/CS6/CC
Adobe Community Professional
Skylar Sweat
on Apr 3, 2018 at 8:02:44 pm
So,
I tried that, it seemed like it had worked, however when i exported the video it only exported 1:02 of it,
Should i just leave a link to the .prproj file?
At this point i cannot seem to get it to work nor synchronize it correctly, nothing has worked thus far,
..Is it even possible to upload a .prproj file to sites like (Dropbox & Onedrive)?
Skylar Sweat
on Apr 3, 2018 at 9:58:23 pm
I couldn't exactly upload it as just the prproj
so it is a zip with all of the projects media inside (including the .prproj file itself which i do not think counts as project media)
It is uploaded here
https://www.dropbox.com/s/fewfkh03rpye87g/Undertale.zip?dl=0
greg janza
on Apr 3, 2018 at 11:26:50 pm
As best I can tell you have two completely different audio files. One is the recorded sound of the video game and the other file is a narration track that accompanies the game. If you did a live recording of the narration track as the game played then it would just be a matter of syncing the starting point of each file. But this appears to be something that you'll need to tweak throughout your timeline to make sure your narration is in sync with the video.
The sync function within Premiere will be of no help to you because it cannot sync two completely different audio files. It can only sync audio files which both share the exact same audio.
Windows 10 Pro
i7-5820k CPU
Nvidia GeForce GTX 970
Adobe CC 2018
Renders/cache: Samsung SSD 950 Pro x2 in Raid 0
Media: Samsung SSD 960 PRO PCIe NVMe M.2 2280
Media: OWC Thunderbay 4 x 2 Raid 0 mirrored with FreeFileSync
Kell Smith
on Apr 7, 2018 at 12:49:48 am
This thread is a few days old, but for what it's worth - I find that slipping audio is a very useful way of working. If the audio is just a little bit off, that works well. It also helps keep the clips in line.
To review it on a clip where audio is varying, like you are describing, I usually match frame it from the timeline to the source monitor, and review and mark audio there, and set an in point. Then either set in and out in the timeline and edit just the audio track in, or just slip the audio in the timeline track, once you know where you want to go.
