Sync cuts from edited angle to unedited angle of two camera setup
Seb Neu
on Mar 27, 2018 at 8:57:56 am
Hi!
Sorry if that sounds complicated.
I record an interview with two cameras at different angles (including a clapper board for audio sync).
At the end, I have 2 files: A and B.
On the road, I'd like to cut A resulting in a Sequence.
After that, I want to bring in B and ideally sync/create cuts that match A in the Sequence.
Is that possible at all?
Thank you so much!
Sebastian
Blaise Douros
Re: Sync cuts from edited angle to unedited angle of two camera setup
on Mar 27, 2018 at 4:29:26 pm
Sounds like you need to create a Multicam sequence.
