DVD Export Shennanigans
Mark Suszko
on Mar 22, 2018 at 6:26:21 pm
Exporting DVD from the timeline, using the standard presets, nothing fancy, the resulting disc will open and run in VLC but not in Apple DVD player or in a real hardware consumer DVD player. What might be wrong?
Mike Jones
Re: DVD Export Shennanigans
on Mar 22, 2018 at 7:14:20 pm
How are you making the dvd once the dvd files have been created? Via Adobe Encore?
Mark Suszko
on Mar 22, 2018 at 7:29:43 pm
No, right off the timeline's own export function, which I guess uses Media Encoder. I'm adding caotions in the metadata settings.
Mike Jones
on Mar 22, 2018 at 8:23:18 pm
It sounds like your creating a data disc with the dvd files you created with Media Encoder( .m2v @ .wav). The next step would be to take those and use Adobe Encoder (from CS6) or another authoring program to create a disc that can be used in a dvd player.
Mark Suszko
on Mar 22, 2018 at 9:56:01 pm
I don't *think* it's a data disk, but I'll play with it some more Friday.
Andreas Kiel
on Mar 22, 2018 at 10:30:00 pm
I think Mike is right .
- Andreas
Spherico
http://www.spherico.com/filmtools
"He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee." - Friedrich Nietzsche, Beyond Good and Evil
Jeff Pulera
on Mar 23, 2018 at 1:17:35 pm
A proper DVD will have a folder called VIDEO_TS and within it, one or more .vob files.
This layout is created when you author the DVD using proper software such as Adobe Encore, Sony DVD Architect, etc.
Jeff Pulera
Safe Harbor Computers
Mark Suszko
on Mar 23, 2018 at 1:58:42 pm
Thanks, Jeff. I've inspected the DVD I burned, and it is as you describe: two folders, and vob and associated files in the proper place.
One funny thing; when playing in Apple's DVD player, the captions appear offset to the left side of the screen instead of centered, but I didn't make any changes in the positioning of captions when making any of this.
Andreas Kiel
on Mar 23, 2018 at 2:05:50 pm
How exactly did you add the captions?
- Andreas
Spherico
Mark Suszko
on Mar 23, 2018 at 3:24:03 pm
Imported SRT to the project, dragged it to the timeline, adjusted position on the timeline to get the timing right. On export, used the metadata settings.
Andreas Kiel
on Mar 23, 2018 at 3:42:33 pm
[Mark Suszko]... On export, used the metadata settings.
Which one and how?
-Andreas
Spherico
Chris Wright
on Mar 23, 2018 at 2:37:42 pm
burn a dvd-r. the dvd+r/rw won't play on some players.
