Colors don't match after import in Premiere
Nicolas Chausson
on Mar 21, 2018 at 5:13:21 pm
I've got a problem in Premiere. When I import my videos, they look very unsaturated in Premiere and the picture is globaly different than my originals medias.
I think it could be a color space issue. It's easy to set it up in After (Project settings > color space) but I can't find anything like this in Premiere...
Someone knows ? :)
Ricky Barrow
Re: Colors don't match after import in Premiere
on Mar 22, 2018 at 11:28:28 am
Is the footage camera raw?
Ricky
Nicolas Chausson
on Mar 26, 2018 at 2:27:54 pm
No t's a XAVC-S (H264) coming from Sony A6500.
Chris Wright
on Mar 26, 2018 at 3:21:27 pm
how are u previewing them? quicktime
uses wrong gamma. if you set vlc to openGl output, it will match premiere for rec.709. or you can get the slog2/3
-> rec 709 lut.
Nicolas Chausson
on Mar 26, 2018 at 4:49:42 pm
Thanks for your answer.
I think it's not a quicktime problem. When I color grade a rush in Resolve then render it, the result is exactly the same in quicktime than the Resolve monitor during the grade. But when I import this color graded rush in Premiere the color problem is also here.
- DaVinci Resolve color space project is set to DaVinci YRGB
- Mediainfo says that the rush rendered is in YUV
Is that normal?
Chris Wright
on Mar 27, 2018 at 2:51:19 pm
is enable fcp legacy in resolve checked? are you using video 16-235 or full 0-255? is nvidia control panel set to 0-255? how does it look with vlc?
Nicolas Chausson
on Mar 27, 2018 at 3:23:13 pm
Sorry but I can't find the checkbox "enable fcp legacy" on the Resolve 14 settings...? Where can I see if I use video in 16-235 or 0-255?
Also, I don't have the nvidia control panel, i'm on mac. And for VLC, the picture looks oversaturated than in resolve...
Chris Wright
on Mar 28, 2018 at 7:19:57 pm
are you using video or full range?
in color managements settings->use mac display color profile for viewers
walter and marc talk about this.
https://forum.blackmagicdesign.com/viewtopic.php?f=21&t=6557&start=100
