Step forward field by field in CS6?
Kell Smith
on Mar 20, 2018 at 10:51:43 pm
I just want to check the field motion step pattern on some clips. In the monitor you can show both fields, but is it possible to step field by field? I'm on CS6.
Pat Horridge
Re: Step forward field by field in CS6?
on Mar 21, 2018 at 7:02:08 am
I don't think there is a field step command like Avid.
You can change which field is displayed. So you can toggle field.
But it's a bit of a dance to check a series of frames.
You end up looking at field one toggling to field 2. Step forward one frame (but you now looking at field 2 still so you have to toggle back to field one then toggle to field 2) then repeat.
Pat Horridge
Broadcast & Post Consultant, Trainer, Avid Certified Instructor
Free online Tutorials at VET digital media academy online http://vimeo.com/channels/752951
pat@vet.co.uk
Kell Smith
on Mar 21, 2018 at 11:38:16 am
Ok thank you!
