trying to make my 30fps footage look like "hyperlapse" footage
Jon Melot
on Mar 20, 2018 at 6:25:52 pm
Hello all,
I've got a BUNCH of 30fps footage, and I am trying to make it look like hyper lapse footatge. basically I just want to go in and take every 30th frame and delete all the stuff in between. is that something that can be done?
-jon
Eric Santiago
Re: trying to make my 30fps footage look like "hyperlapse" footage
on Mar 20, 2018 at 6:38:43 pm
Use time remapping.
Eric Santiago
on Mar 20, 2018 at 6:40:58 pm
Oops I thought I was in After Effects forum.
Shane Ross
on Mar 20, 2018 at 6:48:30 pm
add the clip to the timeline. RIght click on it and choose SPEED/DURATION...now adjust the speed to something like 400%...or 600%...until you get what speed up you are looking for.
Shane
Little Frog Post
Jon Melot
on Mar 20, 2018 at 6:53:46 pm
That wa say first inclination, however, I think what I'm trying to do is more of a posterize... Speeding it up just speeds up all the frames. I want the abrupt change that happens from frame 1 to frame 31, not a really fast sampling of each frame. I'm currently trying to posterize the time to 1fps and then speed it up by 3000%.. see if that gets me any closer? Otherwise, I'm wondering If I need to export each video as a jpeg image sequence, then delete all the intermediary frees (That'd be a bummer of a workflow)
