Equivalent to Avid's "focus" command?
Kell Smith
on Mar 20, 2018 at 12:44:16 pm
Does Premiere have a similar command to toggle focus in the timeline at the playhead, with a one-stroke keyboard shortcut? I'm sure they do, just can't seem to find it Thanks
Todd Perchert
Re: Equivalent to Avid's "focus" command?
on Mar 20, 2018 at 3:01:31 pm
I usually just use the plus (+) and minus (-) keys to zoom in and out of the timeline at the CTI - not the Plus and Minus on the numeric keypad. Also Forward Slash (\) to show entire sequence.
TC
Kell Smith
on Mar 20, 2018 at 6:22:50 pm
Thank you Todd. I use that a lot too. It would be nice if they had a command that would zoom way in with one keystroke but maybe they don't. Ok then I'll make it work. =)
Drives me nuts that you have to zoom way in to the transition to select it and the cursor is constantly changing to a trim cursor, and you can't select it. I think I remember reading that this got better in versions after CS6, not sure.
But a focus shortcut is all-around useful for everything.
