Can't Seem to Add Audio Effects to Multicam Sequence
Harrison Gruber
on Mar 15, 2018 at 11:57:17 pm
Hi. I have some mono tracks where the sound is only coming out of one speaker. I wanted sound to come from both so I tried adding the "Fill Left With Right" Effect to the audio track but it didn't do anything. So then I tried adding it to the original source clip by double clicking the audio in the multicam sequence -->opening the source sequence and adding it there...no dice.
ANY IDEAS?
Todd Perchert
Re: Can't Seem to Add Audio Effects to Multicam Sequence
on Mar 16, 2018 at 4:25:30 pm
You sure it's mono? Is it only on the left (ch.1) channel? Find the clip you need in your Project bin, right-click on the clip and go to Modify, then select Audio Channels. Select format as Mono and make sure your L channel is checked. Hit OK. If your audio was on the right channel, you would select R instead of L. This will make a single channel mono.
TC
Todd Perchert
on Mar 16, 2018 at 4:26:08 pm
I should mention you will need to re-edit into your timeline after you do modify the audio.
TC
