Exports don't match Premiere Pro video look in timeline.
Eric Merklein
on Mar 12, 2018 at 2:26:16 pm
Are there any new tricks out there to try and get video exports to look the same as what I see in my timeline?
I export MP4 at 1080, 10 megs bit rate, double pass and the video levels are still higher than what I see in timeline playback.
Premiere Pro continues to be a sub standard toy.
Thanks for any info.
Eric
Tero Ahlfors
Re: Exports don't match Premiere Pro video look in timeline.
on Mar 12, 2018 at 2:37:18 pm
What are you using to view these files? If you bring it back to Premiere does the export match the sequence?
[Eric Merklein] "Premiere Pro continues to be a sub standard toy."
Mismatches between exports and the sequence are in pretty much all the cases caused by the player playing the file, GPU settings and the operating system color handling and not the program where the file came from.
greg janza
on Mar 12, 2018 at 3:00:50 pm
[Tero Ahlfors] "Mismatches between exports and the sequence are in pretty much all the cases caused by the player playing the file, GPU settings and the operating system color handling and not the program where the file came from."
Agreed. My exports are a perfect match.
Windows 10 Pro
i7-5820k CPU
Nvidia GeForce GTX 970
Adobe CC 2018
Renders/cache: Samsung SSD 950 Pro x2 in Raid 0
Media: Samsung SSD 960 PRO PCIe NVMe M.2 2280
Media: OWC Thunderbay 4 x 2 Raid 0 mirrored with FreeFileSync
Eric Merklein
on Mar 12, 2018 at 3:34:24 pm
Good morning Tero.
When I play my MP4 in VLC video is brighter. When I import back to Pro, chroma is not the same. Same deal in QuickTime.
The problem is getting a good setting in the players and then have everyone I deal with set their system to match.
Not wanting to overstay my welcome, can you please point me to the place where I can adjust playback in VLC or QT?
Many thanks or you help.
Eric
Tero Ahlfors
on Mar 12, 2018 at 5:09:13 pm
[Eric Merklein] "When I import back to Pro, chroma is not the same."
I don't know exactly what you mean by this but when you render to a compressed format that has 4:2:0 chroma subsampling you will lose some color information in the compression. Especially more saturated colors.
I would advise against using Quicktime at all. It is a really bad tool for making any kind of color critical decisions. In VLC you can set different output renderers in the preferences. You should also check your GPU control panel that it doesn't have anything weird going on.
Chris Wright
on Mar 12, 2018 at 7:24:27 pm
vlc set video output openGL output.
nvidia control panel set to 0-255
