GoPro Hero 6 H.265 (HEVC) Choppy Playback in Premiere Pro
Carlen Cyphers
on Mar 9, 2018 at 3:34:39 pm
Hey guys,
I have about an hour worth of Hero 6 footage from my Maui trip. It was shot in 4K 60 FPS, which uses the H.265 (HEVC) codec. The playback seems to be somewhat choppy, even though I have the Preview window set to 1/8 resolution. My computer is no slouch either (although it was primarily built as a gaming computer about 2 1/2 years ago, which was before I got into editing). In case it may be helpful - here is a list of my computer hardware: https://pcpartpicker.com/b/bcnnTW
What should I be doing to make the playback smoother? Should I just use Handbrake to convert all the footage to the H.264 codec before I begin editing the footage?
Thanks.
Ole Kristiansen
Re: GoPro Hero 6 H.265 (HEVC) Choppy Playback in Premiere Pro
on Mar 9, 2018 at 4:21:45 pm
"My computer is no slouch either...."
Do you use an Intel Core i5-6600K 3.5GHz Quad-Core CPU for GoPro 4K 60 FPS H.265 (HEVC)?
Good luck !
Carlen Cyphers
on Mar 9, 2018 at 4:58:51 pm
Thanks for the helpful advice bud.
greg janza
on Mar 9, 2018 at 4:22:12 pm
Don't convert to H264 because it too is a format that requires heavy lifting by your CPU. Before starting an edit, convert all h265 and h264 to an edit friendly codec like pro-res or DNxHD and that'll eliminate the laggy playback issue.
Windows 10 Pro
i7-5820k CPU
Nvidia GeForce GTX 970
Adobe CC 2018
Renders/cache: Samsung SSD 950 Pro x2 in Raid 0
Media: Samsung SSD 960 PRO PCIe NVMe M.2 2280
Media: OWC Thunderbay 4 x 2 Raid 0 mirrored with FreeFileSync
Carlen Cyphers
on Mar 9, 2018 at 5:03:58 pm
Thanks - did some research and I am going to use proxys - seems to be the easiest way to go about it.
greg janza
on Mar 9, 2018 at 5:12:43 pm
Proxies aren't appropriate in this instance. Your originating files aren't worth going back to for mastering.
Transcode all of the H265 and H264 to pro-res or DNxHD and then use those as your master files.
Windows 10 Pro
i7-5820k CPU
Adobe CC 2018
Carlen Cyphers
on Mar 9, 2018 at 5:21:35 pm
Ahh okay I see what your saying. Any links to an article, video, etc on how to transcode the original media?
Carlen Cyphers
on Mar 9, 2018 at 5:25:47 pm
ProRes would be for Mac, so I should likely use DNxHD for PC right?
greg janza
on Mar 9, 2018 at 5:53:47 pm
correct, dnxhd is the equivalent of pro res on pc.
Windows 10 Pro
i7-5820k CPU
Adobe CC 2018
Carlen Cyphers
on Mar 9, 2018 at 5:53:24 pm
What are your thoughts on Cineform vs. DNxHD? I guess the only downside of transcoding vs. using the proxies is that the transcoded files will be BIG and take up a lot of storage space.
greg janza
on Mar 9, 2018 at 7:00:04 pm
Others here on this forum speak highly of Cineform so i kjnow that's an option as well.
Storage space shouldn't be an issue since the cost of storage these days is cheap. Buy more storage if you're short on it.
Windows 10 Pro
i7-5820k CPU
Adobe CC 2018
Carlen Cyphers
on Mar 9, 2018 at 8:11:34 pm
Great thanks! Very true that storage is cheap now a days...I won't worry about it.
Yair Bartal
on Mar 10, 2018 at 3:16:57 pm
I wonder why proxies aren't appropriate in this instance.
Could you elaborate?
greg janza
on Mar 10, 2018 at 4:04:22 pm
The purpose of proxies is to make it possible to smoothly edit high quality (i.e., 4k) footage on a computer that doesn’t have enough power to easily work with the originals. The proxy workflow allows you to build your video with the proxies but to do your final mastering with the high quality original files.
In situations involving h264 or h265 master files, there’s no need to go back to those originating files after transcoding them to an edit friendly codec so therefore the proxy workflow isn’t necessary.
Windows 10 Pro
i7-5820k CPU
Adobe CC 2018
Ole Kristiansen
on Mar 10, 2018 at 4:11:07 pm
Do not know if changes have been made to GoPro Hero 6 H.265 and Gopro Studio!
Many times, when I shoot with my GoPro Hero 4 Black - I take the footage into GoPro Studio - starts the first trim of the recordings - remove fish eyes and saves the recordings like Cineform intermediate .avi or .mov!
Yair Bartal
on Mar 10, 2018 at 4:15:09 pm
That's fine, but why transcode them to an edit friendly codec in the first place and not use proxies instead?
greg janza
on Mar 10, 2018 at 4:28:50 pm
H264 and H265 files are CPU intensive and therefore I would advocate to always transcode them to pro-res or DNxHD before editing. It’s a one step process with no need to round trip as with proxies.
Windows 10 Pro
i7-5820k CPU
Adobe CC 2018
Yair Bartal
on Mar 10, 2018 at 4:55:00 pm
Well, if one has a slow computer, proxies would still be lighter to edit than high quality files, and at the end one just exports with the originals. I think it's a better workflow, but that's me.
Ole Kristiansen
on Mar 10, 2018 at 5:09:09 pm
It's probably a matter of defining "better workflow"!
It also depends on what the recordings will ultimately be used for!
Can you tell why you think proxies are a better workflow?
Yair Bartal
on Mar 10, 2018 at 5:18:21 pm
Well, I've just made a test on a 20 sec UHD H264 clip using PP 2017.1.2:
- Transcoding it to a high quality file - DNxHR HQX UHD resulted in a 728 mbs file.
- Making a proxy file - Cineform 720P resulted in 69 mbs file.
It seems to me that a slow computer can cope better with the proxies workflow.
Having said that, I've been told that proxies are not reliable for color correction, so... one has to decide.
Ole Kristiansen
on Mar 10, 2018 at 5:28:26 pm
Yes, with your "better workflow" you need to make color correction with the original H.265 before export!
"Transcoding it to a high quality file - DNxHR HQX UHD resulted in a 728 mbs file."
Why do you want to transcode to DNxHR HQX UHD, with GoPro 6, which is recorded with 78Mbit for Protune? Is it not overkill?
Yair Bartal
on Mar 10, 2018 at 5:40:48 pm
"Why do you want to transcode to DNxHR HQX UHD, with GoPro 6, which is recorded with 78Mbit for Protune? Is it not overkill?"
You can't compare apples to tomatoes.
That GoPro 6 file is highly compressed and that's why it's only 78 mbs.
It's always a question if you prefer a highly compressed file which taxes your CPU or a high bit rate file which taxes your disks.
With proxies you avoid both.
greg janza
on Mar 10, 2018 at 5:55:09 pm
[Yair Bartal] "It's always a question if you prefer a highly compressed file which taxes your CPU or a high bit rate file which taxes your disks."
With the cost of storage being ridiculously low, the size of transcoded files shouldn't be an issue.
DNxHD and Pro-res are file types that work natively with Premiere and therefore even if you have a lesser computer they will play back just fine.
Using proxies for H264 or H265 files defeats the purpose of streamlining your edit since if you went back to the H264/H265 files for mastering you'd be right back where you started with CPU intensive files.
Windows 10 Pro
i7-5820k CPU
Adobe CC 2018
Yair Bartal
on Mar 10, 2018 at 6:11:52 pm
Well, it's up to the OP (and anyone else) to decide if the cost of FAST storage is ridiculously low for him, if HIS lesser computer can cope with high bit rate files and if he would rather struggle during editing with his lesser computer or export with the originals overnight or during the weekend (if that's practical).
The bottom line I guess is: to each his own... :)
Ole Kristiansen
on Mar 10, 2018 at 6:17:03 pm
Okay, GoPro owns Cineform codec!
So why not use: GoPro Cineform YUV 10bit, quality High
UHD 3840x2160, overall bit rate: 235Mb / s
"You can not compare apples to tomatoes."
Hmm, maybe you think I do not know anything about video editing etc?
Yair Bartal
on Mar 10, 2018 at 7:07:03 pm
"So why not use: GoPro Cineform YUV 10bit, quality High
UHD 3840x2160, overall bit rate: 235Mb / s"
That's still about four times the bit rate of the proxies, but it's not the point.
The point is that one should consider all relevant info and decide for himself based on the relative ease of editing vs exporting.
The proxies workflow is better for me.
"Hmm, maybe you think I do not know anything about video editing etc?"
Well, I do not know what you know and vice versa and if you were insulted I apologize.
Yair Bartal
on Mar 11, 2018 at 7:17:39 pm
BTW, I've just tested the same clip with GoPro Cineform YUV 10bit and with the default quality value of 4 (maximum is 5) and the bit rate turned out to be 455 mbs.
Carlen Cyphers
on Mar 10, 2018 at 6:41:41 pm
Couldn't you just render out a DNxHD file at the end though? You don't use all the footage you shoot, so why not just make proxies on the front end and then render out a master DNxHD file at the end?
I see what your saying though. It probably is not much more work to just trasncode to Cineform or DNxHD at the front end even if you don't use all the footage. Probably what I will do from now on.
Carlen Cyphers
on Mar 11, 2018 at 4:43:52 pm
So I transcoded about 300 clips from my Maui trip to Cineform YUV 10 bit. 690GB! Holy cow...how are people handling that much data? This has become pretty overwhelming. Just not sure how to handle data sizes that big.
Carlen Cyphers
on Mar 14, 2018 at 9:25:59 pm
Revisiting this thread...I had over 300+ clips (between 5-15 seconds) - transcoded to Cineform it was ~600GB. This just isn't practical. If every Premiere Project I have is 600GB, there is no way I can store that much data long term. So in this case I just don't see any other way of doing it other than using proxies.
Shane Ross
on Mar 14, 2018 at 10:36:07 pm
[Carlen Cyphers] "If every Premiere Project I have is 600GB, there is no way I can store that much data long term."
A 1TB USB3 hard drive costs $60. So you can have your main MEDIA drive that you put the media on while working...a nice fast one, but then when you need to "archive," get the $60 drive....bill it to the client as "storage." Done. Storage is cheap.
Shane
Little Frog Post
Carlen Cyphers
on Mar 14, 2018 at 10:44:45 pm
Understood - the customer is myself.
I realize this site is largely for professionals and those who make a living or a partial living doing this type of work...I don't fit that bill.
Shane Ross
on Mar 15, 2018 at 12:34:31 am
Ah...understandable. Well, hmmm...how to make this footage that's not easy to edit, easy to edit, yet still decently archivable. That's the trick..
Shane
Little Frog Post
