Adjustment Layer Not Working Pro 2018
Eric Merklein
on Mar 8, 2018 at 4:32:16 pm
Greetings.
I have a video track 1 and added adjustment layer to track 2, then 3.
The problem is that when I try to adjust motion control in the adjustment layer, nothing happens. It worked just fine in Pro 2017.
Any thoughts out there? Am I missing a command setting?
Thanks much.
E
Todd Perchert
Re: Adjustment Layer Not Working Pro 2018
on Mar 8, 2018 at 6:21:55 pm
I didn't think that was ever possible. Are you sure you didn't use an effect like 3D? I'm on 2017 and Adjustment Layers motion control does not do that.
TC
Eric Merklein
on Mar 9, 2018 at 2:43:03 pm
Todd - You are absolutely correct.
It's been a while since I've used the adjustment layer and I forgot that we have to add the Transform effect.
Thanks for your kind assistance.
E
