Can I replace audio in OP1a MXF without retranscoding the video?
brad hebert
on Mar 7, 2018 at 3:21:05 pm
I want to import an MXF OP1a and replace the audio tracks without changing the video at all. Is there a way to do this without re-encoding the video?
Jon Doughtie
Re: Can I replace audio in OP1a MXF without retranscoding the video?
on Mar 7, 2018 at 5:31:36 pm
You want to completely replace the audio tracks? Just pull video-only onto the timeline.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2017.1 (as of 8/2017)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
brad hebert
on Mar 7, 2018 at 5:42:42 pm
I want to avoid retranscoding the video (XDCAM MPEG-2).
Blaise Douros
on Mar 7, 2018 at 5:55:12 pm
No--if you're changing anything about the file, that means re-rendering. Just bring the clip in, replace the audio, and export to a lossless format like ProRes 422.
brad hebert
on Mar 7, 2018 at 6:59:14 pm
Ok, then. Much appreciated!
brad hebert
on Mar 8, 2018 at 7:06:24 pm
Actually, I found an export option that just rewraps the file. So, it seems like you were incorrect?
Bouke Vahl
on Mar 9, 2018 at 5:49:46 am
I don't know if it's possible with Premiere, but it is definitly possible.
If you think you have found a way, just see how fast it is. If it's lightning fast, the video is copied instead of transcoded.
hth
Bouke
http://www.videotoolshed.com
Ole Kristiansen
on Mar 9, 2018 at 10:46:43 am
I think you just have to enable the smart rendering for OP1a MXF !
