Move clip with exact amount of seconds through timecode field
Allard DePallerd
on Mar 6, 2018 at 10:13:24 am
Hi guys..
I know I can use the timecode field in CC to move my playhead an specific amount of seconds on my timeline.
So if I type +31.00... it will move my playhead on my timeline 31 seconds later...
My question is.. Can I do this same technique with a clip selected, so that it moves the clip automatically 31 seconds? (or whatever time i want) (so not just the playhead, but the selected clip (s) aswell.
I think I did this once by accident.. and it would be a usefull feature for my work...
thanks!
Tero Ahlfors
Re: Move clip with exact amount of seconds through timecode field
on Mar 6, 2018 at 10:15:44 am
If you have clips selected they will be moved instead of the playhead.
Allard DePallerd
on Mar 6, 2018 at 10:45:56 am
Thank you for your reply
I must be doing something wrong.. when I select a clip and add some seconds in the timecode window... it's still the playhead that moves and not the clip...
Jon Doughtie
on Mar 6, 2018 at 6:30:49 pm
Are you using "+" or "-" modifiers in front of the time entry?
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2017.1 (as of 8/2017)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
Allard DePallerd
on Mar 7, 2018 at 9:32:08 am
Yes I am...
I select the clip, then I click in the timecode field, and type something like +31.00
And then just my playhead moves..not the clip...
Tero Ahlfors
on Mar 7, 2018 at 10:23:15 am
[Allard DePallerd] "I select the clip, then I click in the timecode field, and type something like +31.00"
When you click the timecode field you're entering the timecode. Instead of that select the clip, press numpad +, enter the value, press enter.
Allard DePallerd
on Mar 7, 2018 at 10:54:18 am
Ahhhh so that's what i was doing wrong... I clicked the timecode box first...
Thank you very much for helping me out..problem solved!
regards, Allard
