Delete Audio From Video Clip Without Unlink Clip ?
Deep Maithani
on Mar 4, 2018 at 12:37:06 pm
Hi
All Greeting Of Day!
I am finding Solution for Deleteing "Audio only" From my Video Clips Without Doing Unlink Clips
its possible in APPro ?
Currently I am Doing First Select Clip then Cntrl+L then again Selecting audio Cilp separately then pressing Delete !
its taking too much time
in Edius i Used first select the then Press Alt+C audio will be Removed !
finding this kind of solution, Please Guide i am new in APPro
Thanks In Advance
Dave LaRonde
Re: Delete Audio From Video Clip Without Unlink Clip ?
on Mar 5, 2018 at 7:02:58 pm
It's very easy to disable the audio on a clip when it's in the Source window. Look at the extreme left part of the timeline, find the audio and click on it.
Dave LaRonde
Promotion Producer
Syahir Ismail
on Mar 6, 2018 at 11:39:49 am
I think I understand what you're trying to achieve here.
I'm a Mac user,
Option + Mouse Left Click (Select) to select the clip individually without selecting both Video & Audio.
Hope this is what you meant.
Let me know if it is. Thanks.
- An editor just transitioning from FCP 7 to Premiere Pro.
Roger Averdahl
on Mar 6, 2018 at 12:05:08 pm
Hold down the Alt-key and at the same time click on the audio. This selects only the audio and now you can press Delete to remove the audio. No need to unlink since the Alt-key temporary unlink as long as the Alt-key is held down. You can do this for video as well.
You can also hold down the Alt-key and lasso select multiple clips and delete let´s say 100 audio clips in one go.
Deep Maithani
on Mar 7, 2018 at 6:50:26 am
Wow its Work!
Thanks A Lot Sir..
