Export sequence in/out points changed in CC 2018?
Mateo Brooks
on Mar 2, 2018 at 2:10:11 pm
Our previous work computer used CS5.5, and a small feature I used was the in/out point on the sequence, the shortcut used to be alt-[ but it no longer works.
I noticed in CC, Alt-[ does nothing, but you can do something similar for exporting a piece of a sequence using just the regular in/out points (i and o shortcuts)
----EDIT-----
Completely forgot the about the Work Area Bar, it doesn't show up in CC2018 by default but I've figured it out! Problem solved!
Tero Ahlfors
Re: Export sequence in/out points changed in CC 2018?
on Mar 2, 2018 at 2:17:19 pm
You can enable the work area bar from the timeline panel menu. Click on the three lines next to the sequence name.
